Restriction on LAN to LAN VPN tunnel between PIX
Currently i have LAN to LAN tunnel on a PIX515e, with OS version 6.22
What is the best way to just restrict one of the tunnel, only outgoing traffic is allow, and drop all incoming traffic from remote site?
if we take out sysopt permit-ipsec, it will block all tunnel, are there any other way to get around this?
any suggestion would be really appreciate!! thanks
Simon
1 REPLY
Bronze
Re: Restriction on LAN to LAN VPN tunnel between PIX
If what you mean is permitting an user to access from outside to inside and denying him access the other way around, then this is not supported.
123
