02-17-2004 03:24 PM - edited 02-20-2020 11:15 PM
Hey all, I have a PIX 525 that crashed on me twice today, running 6.3(3). In both cases the crashinfo file generated is corrupt. Is there any way to retrieve the partial file from flash to have a look at it?
The file definately does exist, but I can't do anything with it on the PIX:
psifw01# show crashinfo
Show crashinfo failed: bad or missing header magic number
psifw01# show flash
flash file system: version:3 magic:0x12345679
file 0: origin: 0 length:1941560
file 1: origin: 1966080 length:47935
file 2: origin: 2228224 length:1921
file 3: origin: 2359296 length:4748324
file 4: origin: 7208960 length:131072
file 5: origin:16646144 length:308
My secondary (currently active) PIX 525 shows the following under a show flash:
psifw02# show crashinfo
No crash file found.
psifw02# show flash
file 1: origin: 1966080 length:47934
file 2: origin: 2228224 length:1927
file 4: origin: 0 length:0
In this case, is file 4 the crashinfo? Or is it also the "flashfs downgrade information for the show flashfs command" as posted in the 'PIX 515e "show flash"' thread.
Thanks.
Joshua
02-17-2004 07:26 PM
Joshua,
Interesting. I have seen this message a few other times but am not sure of the cause. Can you issue a 'clear crashinfo' on the primary PIX (in config mode) and wait for another crash and failover? Then try gathering the 'sh crashinfo' output?
As for the sh flash output, the info I posted earlier was for a pre-6.3 PIX. The file system changed in 6.3 so you are correct that file 4 is the crashinfo on a PIX running 6.3. See the table below:
PIX Ver 6.2 and lower (ver 2 filesystem)
file 0: PIX binary image
file 1: startup config
file 2: IPSec key and certificate information
file 3: PDM image
file 4: filesystem record
PIX Ver 6.3 and higher (ver 3 filesystem)
file 2: IPSec key and certificate information.
file 3: PDM image
file 4: Crashinfo (last saved traceback and show tech output)
file 5: filesystem record
Scott
02-18-2004 05:18 AM
Hi Scott,
This is already the second time it's happened. The first time it happened yesterday, I also wasn't able to view the crashinfo file, so I cleared it off. The second time it happened it was the same thing.
I'm trying to determine what the cause might be at the moment, but it's not always that easy if I can't read the file ;-)
Would it be safe to say that if the file was created in the first place, it's a software based crash?
The only other information I can find on the crash is that the secondary reported "no power detected from mate" and took charge.
-Joshua
02-18-2004 06:48 AM
Joshua,
OK, got ya. I was hoping this would help but I guess not. Yes, you can assume that this was a software forced crash. The fact that you see something in file 4 on the flash and the syslog message from the failover PIX, make this an almost certainty. The only other option I can think of would be to setup a machine that is constantly logged into the console on the problem PIX. If the PIX should crash again, the crashdump should be displayed to the console. Set your console session to capture the whole session to make sure you get the info. Once you get the crashdump, open a TAC case so that our engineers can decode the crash for you and also dignose the 'sh crashinfo' problem. Sorry for the issues. Good luck!
Scott
02-18-2004 07:34 AM
Thats too bad..
Thanks anyways. I'll have to dig around to find some machines I can record console output to.
-Joshua
