route down/up - please help/
I understand the alarm is generated based on network connectivity or not.
But, I'm seeing (in my log files) tenths of a second between a route up and then a route down. So fast, there not even registering on the director gui.
I examine the postoffice config files, but can't seem to find anything set to react like that.
In addition, how can I adjust this if I'm willing to accept (or at least have to accept) a few seconds of network latency due to possible traffic load.
Any help would be greatly appreciated.
Sensors are 3.0(5)S18 and director is 2.2.3 (S18).
Thank-you.
  • Other Security Subjects
Re: route down/up - please help/
Hi Jeff,
This may help...
On the sensor appliance, edit /usr/nr/etc/postofficed.conf file to add the following token:
HeartBeatIntervalMultiplier 12
Ward.
Thank you. I plan to make the change.
Would it be too much trouble to explain some details behind your response? I's like to at least have a good working understanding before I implement the change.
Thanks again.
Hi Jeff,
Via the postoffice protocol, the sensor sends a heartbeat message to the other CIDS machines it's communicating with. The acknowledgement to this message is the sensor's indication that the route is "up". There's a timeout value that the sensor uses to wait for the response before it declares the route as "down". This timeout is HeartBeatIntervalMultiplier x HeartBeat seconds.
The default HeartBeatIntervalMultiplier is 3 and the default HeartBeat is 5 seconds. So, by increasing the HeartBeatIntervalMultiplier, you're configuring the sensor to wait longer for the response to the heartbeat message that it sent before declaring a "route down" to the corresponding CIDS machine.
Ward.
94
