route for directly connected int
is it always a good practice to have a route for the directly connected int or is it a must?
Re: route for directly connected int
Routing depends on your network setup/connectivity.
You can have it (static or via OSPF/RIP) to ensure the remote network across another L3 device(s) that connected to PIX is reachable as well.
For simple setup like inside connect to inside switch (flat Vlan), no route is required. Same goes to other interfaces like DMZ, except for outside where you need to have a default or static route to your internet router.
For such simple setup, if you issue command 'sh route', you will see this automated route entry built by PIX.
But if you need to ensure communication from one segment to another, and need to pass through or hosted on another L3 device (i.e internal router), then a route is a must.
So, whether it is a good practice or a must,
it depends on your network setup.
AK
say if it's between dmz to inside...then...
As soon as you give an ip address and mask to an interface and do a no shut on it, a route will be created for the network address.
For DMZ to inside (or vice-versa), PIX will create the route automatically. Make sure interfaces are up. This happened without having to have address translation between the segment (but translation or no NAT is required later in order to allow hosts in both segments to talk to each other).
But this is for directly connected interface only, not including segment behind L3 device in DMZ or inside segment.
AK
ok but why do we configure route for all inside hosts say like route inside gateway(which is inside int add) is this for communication with a outside world say like l3 devices after the ouside interfaces
We don't need to do that, and not even required. PIX will generate it automatically.
Example, if this is your IP Addresses looks like:
ip address outside 10.1.1.1 255.255.255.0
ip address inside 10.0.0.2 255.255.255.224
ip address DMZ 172.16.5.10 255.255.255.0
route outside 0.0.0.0 0.0.0.0 10.1.1.254 --> * default route to internet router
Then, PIX will create automatic route to its respective interfaces:
pixfirewall(config)# sh route
outside 0.0.0.0 0.0.0.0 10.1.1.254 1 OTHER static ---> tied to the default route (see *)
inside 10.0.0.0 255.255.255.224 10.0.0.2 1 CONNECT static --> auto-generated by PIX
outside 10.1.1.0 255.255.255.0 10.1.1.1 1 CONNECT static --> auto-generated by PIX
DMZ 172.16.5.0 255.255.255.0 172.16.5.10 1 CONNECT static --> auto-generated by PIX
Even if you try to add it (except default route to internet router), PIX will reject it (route already exists).
AK
You only need that if you have another L3 device (switch/router) hosting another segment:
outside, subnet x <--> PIX <--> Inside (ip yy.yy.yy.1/24 <--> FE0/0 (ip yy.yy.yy.2/24) <-->Router <--> FE0/1 (ip zz.zz.zz.1/24)
Then only you need to add the following in your pix:
route inside zz.zz.zz.0 255.255.255.0 yy.yy.yy.2 1
197
