Router between VPN3002 and Clients
we've tested the following configuration:
internet--VPN3002--PrivatLAN--Router--Clients
In both cases (PAT/Network Mode) we got it not working
only when the client is connected at the privat lan.
-Is this normal?
-How much Clients (mac-addresse or IP-Addresses)
can we connect to the VPN3002?
-When only one from both what is when we use PAT
on the router?
regards
Karlheinz
1 REPLY
Re: Router between VPN3002 and Clients
The 3002 would only tunnel subnet that is local to its interface. What you are
trying to do is not a supported configuration. You would need something like
a router and do a lan to lan vpn to the head end concentrator.
94
