You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Router flash read-only
I'm configuring my router as a TFTP server that saving other routers' running configuration into flash memory. But problem here is router's flash memory is read -only and no router could address it....
Router#show flash
System flash directory:
File Length Name/status
1 15778276 c2500-js-l.122-12.bin
[15778340 bytes used, 998876 available, 16777216 total]
16384K bytes of processor board System flash (Read ONLY) <<<<<<<
Router#dir flash:
Directory of flash:/
1 -rw- 15778276 <no date> c2500-js-l.122-12.bin
16777216 bytes total (998876 bytes free)
I'd like to open the lock so that this router could virtually be a TFTP server.
What can I do ?
thanks!
  • Other Security Subjects
1 REPLY
Re: Router flash read-only
The 2500 series routers run from flash, unless the image is compressed and there is enough DRAM in the router to decompress the image to and run it.
107
