Router to Check Point VPN issue
I am using a 1841 router for VPN connection with multiple sites easily established VPN from 1841 to 871 but after that i have to make a vpn tunnel from 1841 to check point firewall which i am not been able to establish.Plz do let me know is it can be the issue with the crypto map as i am using same crypto map fro both tunnels with different transform set & did some body tried the vpn from cisco to check point before
Thanks in advance
1 REPLY
Silver
Re: Router to Check Point VPN issue
Yes L2L tunnels between Cisco and checkpoint are possible. I have done several installations successfully. Make sure that your phase 1 and phase 2 policies match the Checkpoint side. You will need to use the same crypto map since you can apply one crypto per interface.
Let me know how it goes,
259
