Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Router to Cisco VPN client VPN connection Version problem?
I have a Cisco VPN client connection to a cisco 2600, if i'm using the client version 3.5.2, it's working, once i upgrade to 3.6.4, i can't even finish the negotication. does it has something to do with the AES issue?
how can i get around this?
Simon
Bronze
Re: Router to Cisco VPN client VPN connection Version problem?
Simon,
The VPN client should send AES in the ike proposal along with 3des and des. The router should accept either a 3des or a des proposal eventually. Can you send debug cry isa and debug cry ip from the router?
Jazib
Thanks for your reply, here is the debug message which i got from the router.
any suggestion or hints would be appreciates
04:51:04: ISAKMP (0:0): received packet from 67.194.152.99 (N) NEW SA
04:51:04: ISAKMP: local port 500, remote port 500
04:51:04: ISAKMP (0:2): (Re)Setting client xauth list user-test and state
04:51:04: ISAKMP: Locking CONFIG struct 0x82CC85C8 from crypto_ikmp_config_initi
alize_sa, count 2
04:51:04: ISAKMP (0:2): processing SA payload. message ID = 0
04:51:04: ISAKMP (0:2): processing ID payload. message ID = 0
04:51:04: ISAKMP (0:2): processing vendor id payload
04:51:04: ISAKMP (0:2): vendor ID seems Unity/DPD but bad major
04:51:04: ISAKMP (0:2): vendor ID is XAUTH
04:51:04: ISAKMP (0:2): vendor ID is DPD
04:51:04: ISAKMP (0:2): vendor ID is Unity
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 1 against priority 3 policy
04:51:04: ISAKMP: encryption... What? 7?
04:51:04: ISAKMP: hash SHA
04:51:04: ISAKMP: default group 2
04:51:04: ISAKMP: auth XAUTHInitPreShared
04:51:04: ISAKMP: life type in seconds
04:51:04: ISAKMP: life duration (VPI) of 0x0 0x20 0xC4 0x9B
04:51:04: ISAKMP: attribute 14
04:51:04: ISAKMP (0:2): Encryption algorithm offered does not match policy!
04:51:04: ISAKMP (0:2): atts are not acceptable. Next payload is 3
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 2 against priority 3 policy
04:51:04: ISAKMP: hash MD5
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 3 against priority 3 policy
04:51:04: ISAKMP: auth pre-share
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 4 against priority 3 policy
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 5 against priority 3 policy
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 6 against priority 3 policy
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 7 against priority 3 policy
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 8 against priority 3 policy
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 9 against priority 3 policy
04:51:04: ISAKMP: encryption 3DES-CBC
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 10 against priority 3 policy
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 12 against priority 65535 poli
cy
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 13 against priority 65535 poli
cy
04:51:04: ISAKMP: encryption DES-CBC
04:51:04: ISAKMP (0:2): Hash algorithm offered does not match policy!
04:51:04: ISAKMP (0:2): Checking ISAKMP transform 14 against priority 65535 poli
cy
04:51:04: ISAKMP (0:2): atts are not acceptable. Next payload is 0
04:51:04: ISAKMP (0:2): no offers accepted!
04:51:04: ISAKMP (0:2): phase 1 SA not acceptable!
04:51:04: ISAKMP (0:2): incrementing error counter on sa: construct_fail_ag_init
04:51:04: ISAKMP (0:2): Unknown Input: state = IKE_READY, major, minor = IKE_MES
G_FROM_PEER, IKE_AM_EXCH
04:51:09: ISAKMP (0:2): received packet from 67.194.152.99 (R) AG_NO_STATE
04:51:09: ISAKMP (0:2): phase 1 packet is a duplicate of a previous packet.
04:51:09: ISAKMP (0:2): retransmitting due to retransmit phase 1
04:51:09: ISAKMP (0:2): retransmitting phase 1 AG_NO_STATE...
04:51:10: ISAKMP (0:2): retransmitting phase 1 AG_NO_STATE...
04:51:10: ISAKMP (0:2): incrementing error counter on sa: retransmit phase 1
04:51:10: ISAKMP (0:2): sending packet to 67.194.152.99 (R) AG_NO_STATE
Bronze
Hi there,
it does look like your router is not negotiating the isakmp policy. I don't know what's the configured isakmp policy is on your router. But try to configure a policy similar to the one listed below and see what happens
encr 3des
hash md5
group 2
auth pres
Jazib
198
