router to PIX isakmp/ipsec renewal issue
I used the almost same config as
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094498.shtml
IOS router 12.0(7)T on 2621 (8MB flash)
PIX 515 6.2
the tunnel works fine during lifetime of 3600 seconds, then just after renegociation, it drops the connection.
the only way is to clear crypto sa on PIX and / or the router to re initialize the tunnel.
I tried PFS Y/N, I tried keepalive on both ends, always the same issue.
any idea?
Re: router to PIX isakmp/ipsec renewal issue
Hi I had similar issue ages ago but adding the below command on the router fixed teh issue
crypto isakmp keepalive 10
I have these keepalive on the PIX and the router.
But it is isakmp keepalive.
I think the pb comes from the ipsec renewal since it appears at the end of the lifetime of ipsec, not isakmp
145
