Routing Issue
Hi all i am new to remote Access VPN, i configured it using ASDM VPN Wizard and now using vpn client i am able to connect to the network but unable to access internal network resources ,
should i enable any routing in ASA for this tunnel ?
Re: Routing Issue
you should exclude traffic VPN traffic from the NAT.
Re: Routing Issue
How can i do it can i use any command or through ASDM
Re: Routing Issue
access-list NO-NAT permit ip any x.x.x.x mx.mx.mx.mx
nat (inside) 0 access-list NO-NAT
where x.x.x.x - network, which includes vpn client pool.
Re: Routing Issue
ok i got the point but i am using PAT over my router which connects my firewall to internet,
so do u mean i should exclude these addresse over my Router where my natting takes place
is it right ?
i am using nat exemption already over my ASA
Re: Routing Issue
what did you mean when you said " i am able to connect to the network but unable to access internal network resources "?
could you show the configuration?
Re: Routing Issue
Hi all, I seem to be having the same problem. I can connect my vpn client to the Cisco PIX, but I cannot access my internal IP ranges. My network is as follows:
I have one old IP range (192.168.1.0/24) connected without VLAN ID on the inside interface
I have one new infrastructure VLAN with the range of 172.16.100.0/24 and VLAN ID 100
I have one new Clients VLAN with the range of 172.16.101.0/24 and VLAN ID 101
I have a VPN pool in the range 172.16.102.0/24
If I connect, I get an IP address in the correct range (172.16.102.1). I also can see the secured routes showing up in my statistics screen. However, I am unable to ping, rdp or smb any of my resources on either one of the local networks.
Maybe my problem is caused due to the application of multiple IP ranges, but the answer to my problem might just answer his problem as well.
(In my case it is a PIX problem, but might be the same as with your ASA)
Attached you can find my modded configuration
137
