Community Member
Routing issues with PPTP VPN traffic.
How do I route the PPTP traffic from vpn clients to get to other networks on my "inside" interface? They connect fine but can only see the subnet that the PIX is on. PPTP clients are assigned addresses from say the pool and the subnet that the PIX is on is How do I route to say the subnet on the inside net? Do I add a route for the pptp addresses on the PIX or my internal routers or am I missing something else?
Community Member
Re: Routing issues with PPTP VPN traffic.
Sounds like you have two subnets on your inside network. If this is the case you will need to specifiy in the pix a default route to get to the remote subnet. Is there a router before the pix on the inside of your network? (router-pix-internet). If there is then the route should point to the interface that is directly connected to the pix.
Also in the router you should have routes defined to get to your other subnets. Hope this helps.
