Community Member
Routing Isues
I have a unix based FTP server on my PIX520 DMZ, I can FTP to the box
from the internal network. I've added an access-list and static to translate
the external-DMZ addresses. I have a packet sniffer on the DMZ and If i open
an external to DMZ FTP session I see the first FTP packet hit the DMZ destined for the FTP server. However the FTP server never replies, I assume because it has no route to the source Ip address (External Network), If I add a gateway to the FTP server (as the PIX DMZ address) I loose internal connectivity, but still don't get the external portion to work?. How should gateways and routing be set up on the FTP box?
1 REPLY
Community Member
Re: Routing Isues
This sounds to me like you have an error with either your static or your conduit / access list. If you post the config (minus passwords) I will take a look for you.
Routing shouldn't be the issue as you should have a default route pointing out from your outside interface towards a router.
95
