12-06-2001 10:46 AM - edited 02-21-2020 11:31 AM
We are having a problem getting RSA SecureID working with our VPN 3030. Our RSA box is set up using RADIUS as well. I think its a bug....
Any ideas???
12-06-2001 11:51 PM
Make sure you are using the latest 3000 concentrator code and then you could at least enable the AUTH and
AUTHDBG event classes on the 3000 box, and do a test authentication from the box (from the Configuration, System, Authentication Servers) and see the Filterable event log and see what is happenning.
12-07-2001 07:51 PM
I want to know where I can get the latest code for VPN 3000?
I can't find latest code in "Software Center>Cisco Secure Software"
02-06-2002 12:10 PM
This info can be found on RSA VPN3000 document:
The Cisco VPN3000 has RADIUS support, yet does not work with ACE/Server RADIUS since it does not support RADIUS challenges, and therefore does not support new pin/next tokencode mode.
Maybe that your problem ?
Anssi
03-07-2002 07:06 PM
This solution may be more expensive than what you're looking for, but I've installed a PIX 515 that authenticates VPN users via TACACS+ to a Cisco Secure server. The Cisco Secure server authenticates SecureID cards using the ACE Agent.
This has been working fine for about a year now. Maybe you could get your company to buy Cisco Secure ACS and use that as your RADIUS server, authenticating against the RSA database.
Eric
