Community Member
Running Configuration Changed log messages
For a while now I receive in the log the following messages.
000194: Jun 21 14:21:21.968 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: ADD6B3E84E34792525677E787C0BDBCD
000195: Jun 21 14:21:22.089 CEST: %AUDIT-5-STARTUP_CONFIG: Startup Configuration
changed. Hash: 6E67049B23CCF438C4D70381AD0095A2
000196: Jun 21 15:05:46.275 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: 49E0B0736FFFA0921BFE99323D9A5A74
000197: Jun 21 15:15:33.853 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: A6756E027000D1238D45C0B92E3F16A6
000198: Jun 21 15:20:30.128 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: 0DECE07D3A4108E522442D014044CA08
000199: Jun 21 15:25:24.511 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: 722BCA2A49D1031EC01663B10391C862
000200: Jun 21 15:35:19.970 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: 3EFAA0A24F4C9463900C9C415AAEA30A
000201: Jun 21 16:04:57.746 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: 5C5EBC73FCAE83A3606ABB8F5872DA89
000202: Jun 21 17:04:07.777 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
nged. Hash: 994E7622596A7C3A2BEDCC8F7E198979
000203: Jun 21 19:47:03.472 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
000204: Jun 21 19:51:57.853 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
000205: Jun 21 19:56:51.549 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
000206: Jun 21 20:01:43.450 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
000207: Jun 21 20:06:38.636 CEST: %AUDIT-5-RUN_CONFIG: Running Configuration cha
Since I didn't change anything in the configuration I am wondering what causes this. The router is a 1761 with IOS 12.3(2)XE using ADSL interfaces, IPSEC VPN's and Firewall.
Thanks in advance
Re: Running Configuration Changed log messages
Strange. Is the ADSL interface using DHCP?
Community Member
No, I use a ip address on the dialer, together with ppp authentication, ip inspect and crypto map.
Rgrds
I'm lost then.
I know it's hassle but you could try "aaa accounting" to see what's changing.
274
