same-security-traffic intra-interface and ACLs
cbadeau
I have an ASA 5520 running v7.2 with a RA VPN without split tunneling. I have enabled same-security-traffic intra-interface and appropriate NATing to get VPN clients to the web. This works. However, I noticed the VPN client web traffic isn't hitting my outside interface outbound ACLs. How do I get my outbound VPN client traffic to hit these ACLs? Thanks-
6 Replies 6
acomiskey
Level 10
Level 10
So you have something like this?
access-list outbound out interface outside
almost:
access-group outbound out interface outside
with
access-list outbound extended deny tcp any host x.x.x.x www
inside can't www to x.x.x.x, but vpn clients can.
I would assume this is because of...
sysopt connection permit-vpn
This makes the traffic bypass the interface acl's. You could disable this with "no sysopt connection permit-vpn", but this would apply to all ipsec vpn traffic.
Another option is to use a vpn-filter assigned to the vpn tunnel group policy.
Hmmm. There's no sysopt in the config. So I am correct that the expected behavior from my config sould be for the www vpn client traffic to hit oubound acls?
Any other ideas?
Try..
show run sysopt
Bingo. So a little digging shows 'sysopt connection permit-vpn' is enabled by default post 7.0. This would explain why I don't see it explicitly in the config. Thanks!
