05-27-2008 08:44 AM - edited 03-09-2019 08:47 PM
ASA5505 config
ip address inside 10.1.1.254 255.255.255.0
nat (inside) 1 10.1.1.0 255.255.255.0
route inside 10.1.2.0 255.255.255.0 10.1.1.253
same-security-traffic permit intra-interface
When I source packets from 10.1.1.1 host I cannot reach 10.1.2.1 host
default-gateway on 10.1.1.1 is 10.1.1.254
If I "route add 10.1.2.0 mask 255.255.255.0 10.1.1.253" to 10.1.1.1 host I can then reach 10.1.2.1 host
What am I missing here? Everything else I need to do works.
Thx,
Phil
Solved! Go to Solution.
05-27-2008 09:47 AM
05-27-2008 09:47 AM
This should make it work.
global (inside) 1 interface
05-27-2008 09:57 AM
Adam - that did the trick!
It would have taken me some time to globalize the inside interface since this is my firs foray into hair-pinning.
Where does Cisco hide this little gem of information?
Thx,
Phil
