sample config using IPSec VPN SPA using BGP WAN
where can i find a sample config which uses bgp as tranport between two locations and encryption is setup over bgp "cloud". Also static or OSPF routes from location a have to be transported between two -or more- locations.
regrads
Frank
Re: sample config using IPSec VPN SPA using BGP WAN
If you want to encrypt OSPF packets using IPSEC, then you need to do configure GRE Over IPSEC and below is the configuration guide that explains on how to set up GRE Over IPSEC Tunnel using the SPA.
http://www.cisco.com/en/US/products/hw/switches/ps708/module_installation_and_configuration_guides_chapter09186a00808a7671.html#wp2028065
Arul
thanks so far, i already used this document. Theres a CPE example which could match(?).
The components i use are more like "all-in-one" CE/PE functionality.
The problem is that i'll use RouteReflector and route-target import/export, so i've no "outside" interface oder vlan to bgp cloud.
121
