11-18-2013 06:58 AM - edited 03-10-2019 12:08 AM
I am looking for sanitization procedures for a 4510 switch. I need to be able to clear any and all IP information or any data that may be stored on the system. I need something official, but since the contract is expired tech support can't talk to me. Anyone have anything?
11-18-2013 01:47 PM
If you plan to get rid of your old equipment then you can't go wrong with the command "format bootflash:".
11-18-2013 08:13 PM
dir all-filesystems
...will show all of the filesystems on the device. You will normally (on a 4510) see running-config in system, startup-config in nvram and vlan.dat in cat_4000_flash. Those three files contain the bits you may be concerned about.
So from console:
write erase
write mem
del cat4000_flash:/vlan.dat
reload
Check again after the reload, running-config and startup-config should be factory default and vlan.dat should not contain your VLAN definitions.
This procedure is described further in the following document:
