Sanitization procedures for Catalyst 4510
I am looking for sanitization procedures for a 4510 switch. I need to be able to clear any and all IP information or any data that may be stored on the system. I need something official, but since the contract is expired tech support can't talk to me. Anyone have anything?
Hall of Fame Super Gold
If you plan to get rid of your old equipment then you can't go wrong with the command "format bootflash:".
Hall of Fame Super Silver
Re: Sanitization procedures for Catalyst 4510
dir all-filesystems
...will show all of the filesystems on the device. You will normally (on a 4510) see running-config in system, startup-config in nvram and vlan.dat in cat_4000_flash. Those three files contain the bits you may be concerned about.
So from console:
write erase
write mem
del cat4000_flash:/vlan.dat
reload
Check again after the reload, running-config and startup-config should be factory default and vlan.dat should not contain your VLAN definitions.
This procedure is described further in the following document:
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml#reset_switch
867
