SDM does not start
Hi All!
I have a 2621xm and want to test SDM. It was not pre-installed so I downloaded sdm22a.zip from Cisco. The setup-util cannot be used, because of a rpc-error. I believe that this has to do with a tighter behaviour of the more recent ios-versions. So I try to install SDM using tftp. I copied sdm.tar, home.tar and home.shtml. Then i point my browser to the routers interface. All looks ok but after some screens I receive the message that SDM was not found on the router. I tried version 22a and 11, results are the same.
Help? Thanks!
Henk
  • Other Security Subjects
1 REPLY
Silver
Re: SDM does not start
Take a look at this procedure and make sure you didn't miss any steps.
http://www.cisco.com/en/US/products/sw/secursw/ps5318/prod_installation_guide09186a00803e4727.html
Hope this helps
Steve
95
