secondary ciscosecure for authenication
I have one CiscoSecure as my primary access server and a second CiscoSecure access server set up as a backup server over the WAN .
can my router point to the secondary tacacs for authenication ?
or it can only point to the primary server and if the primary server fail then it will switch to the secondary for authenication.
1 REPLY
Anonymous
N/A
Re: secondary ciscosecure for authenication
You can have the router pointed to both servers. As long as your database is synchronized, pointing router to either server as primary should work just fine.
83
