Secondary ip address on Nat outside causing VPN problem?
-- begin ciscomoderator note -- The following post has been edited to remove potentially confidential information. Since this was posted on a public forum, it is recommended that passwords be changed including encrypted passwords. Please refrain from posting confidential information on the site to reduce security risks involved. -- end ciscomoderator note -–
I am trying to use a 1720 router with IOS version 12.2.8.T4 to try to connect to a NT server and a NT Exchange server. I am using nat with a secondary address on the nat outside. I can ping the NT server and see the Microsoft Exchange’s information stores but can not authenticate with the with either or browse the local lan. I believe the secondary address on the Nat outside is causing the problem. I have included my configuration. Any help would be appreciated.
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname coin_mach
boot system flash c17001228t4.bin
enable secret 5 --moderator edit--
memory-size iomem 25
clock timezone est -5
clock summer-time est recurring
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip domain-lookup
ip host roslynnt 10.223.223.3
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 3
authentication pre-share
group 2
crypto isakmp client configuration address-pool local remotepool
crypto isakmp client configuration group remoteuser
key XXXXXXXXXX
pool remotepool
crypto ipsec transform-set trans1 esp-des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set trans1
crypto map intmap isakmp authorization list groupauthor
crypto map intmap client configuration address initiate
crypto map intmap client configuration address respond
crypto map intmap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0
ip address 10.223.223.35 255.255.255.0 secondary
ip address --moderator edit-- 255.255.255.240
ip nat inside
speed auto
interface Serial0
description link to CTC
mtu 1492
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
ip unnumbered FastEthernet0
ip nat outside
frame-relay interface-dlci 40
crypto map intmap
ip local pool remotepool 10.4.0.1 10.4.0.254
ip nat pool COIN_MACH --moderator edit-- 64.69.121.21 netmask 255.255.255.240
ip nat inside source list 1 pool COIN_MACH overload
ip nat inside source route-map nonat interface Serial0.1 overload
ip nat inside source static tcp 10.223.223.2 9471 64.69.121.18 9471 extendable
ip nat inside source static tcp 10.223.223.2 9476 64.69.121.18 9476 extendable
ip nat inside source static tcp 10.223.223.2 9470 64.69.121.18 9470 extendable
ip nat inside source static tcp 10.223.223.2 992 64.69.121.18 992 extendable
ip nat inside source static tcp 10.223.223.2 449 64.69.121.18 449 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0.1
ip route 10.0.0.0 255.255.255.0 10.223.223.8
ip route 10.4.0.0 255.255.255.0 Serial0.1
ip route 10.10.0.0 255.255.255.0 10.223.223.8
ip route 10.11.0.0 255.255.255.0 10.223.223.8
ip route 10.12.0.0 255.255.255.0 10.223.223.8
no ip http server
ip pim bidir-enable
access-list 1 permit 10.223.223.0 0.0.0.255
access-list 1 permit 10.11.0.0 0.0.0.255
access-list 1 permit 10.12.0.0 0.0.0.255
access-list 1 permit 10.4.0.0 0.0.0.255
access-list 120 deny ip --moderator edit-- 0.0.0.255 10.4.0.0 0.0.0.255
access-list 120 deny ip 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255
access-list 120 permit ip 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255
access-list 120 permit ip --moderator edit--0.0.0.255 10.4.0.0 0.0.0.255
!The following ports are used to try to connect to my Exchange Servers information Stores
access-list 120 permit udp 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255 eq 135
access-list 120 permit udp 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255 eq netbios-ns
access-list 120 permit udp 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255 eq netbios-dgm
access-list 120 permit udp 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255 eq netbios-ss
access-list 120 permit udp 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255 eq 140
access-list 120 permit udp 10.223.223.0 0.0.0.255 10.4.0.0 0.0.0.255 eq 141
route-map nonat permit 10
match ip address 120
line con 0
password xxxxxxxxx
login
line aux 0
line vty 0 4
password xxxxxxxxx
login
end
1 REPLY
Re: Secondary ip address on Nat outside causing VPN problem?
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
470
