Securid and ppp callback
I found that there are more people having troubles with securid token and callback. But so far I did not see any solutions.
The Problem.
I haven configures ppp callback on a cisco 3640 with mica modems. Dialing in works fine untill the callback is initiated from the cisco. By then the Securid Token is already expired.
Is there a possibility to turn of the second authentication? I tried ppp authentication pap callin. But this doesn't help.
My config:
aaa new-model
aaa authentication login default group radius local
aaa authentication login console enable
aaa authentication login vty local
aaa authentication ppp default group radius none
aaa authorization network default group radius none
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
interface Serial2/0:15
ip unnumbered Ethernet0/0
encapsulation ppp
ip mroute-cache
dialer idle-timeout 600
dialer-group 1
isdn switch-type primary-net5
isdn incoming-voice modem
peer default ip address dhcp
no fair-queue
no cdp enable
ppp callback accept
ppp authentication pap callin one-time
interface Group-Async1
encapsulation ppp
async mode dedicated
ppp callback initiate
group-range 97 126
line 97 126
autoselect during-login
autoselect ppp
script modem-off-hook offhook
script callback callback
modem InOut
transport input all
Raymond Plenter
Re: Securid and ppp callback
radius server will send 3 retries every 5 seconds if it does receive a reply back. You can change these default values using;
radius-server retransmit x (default is 3)
radius-server timeout x (default is 5 seconds)
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t5/radtimou.htm#32440
R/Yusuf
But this will not solve my problem of the timeout of my securid. What I actually would like to do is shut of that second authentication (which is initiated from the cisco as far as i can see).
Raymond
90
