Sensor kpcap Error
Has anyone seen any of these type errors on their sensors? It happens on both v2.5 and v3. The exact error is posted to syslog as:
kpcap: [ID 657229 kern.warning] WARNING: kpcap: quntimeout failed
Re: Sensor kpcap Error
Is this happening on a sensor that is making heavy use of resets? I have looked at the code and this warning can happen when specific timing of events occur within the driver. I think they can be safely ignored, but, if possible, I would like a little more information on when they are happening.
Thanks for replying...
By "resets" do you mean shunning the Src? If so, we are NOT doing this. I am getting this from many different v2.5 sensors.
Sorry I should have been more descriptive. By resets I was refering to the TCP reset action.
No, the sensor is NOT setup to do any TCP resets. Sorry for the delayed reply...
94
