06-28-2001 09:11 PM - edited 03-08-2019 08:25 PM
I have a problem concerning Sensor Upgrade.
I would like to upgrade a IDS-4230-FE sensor
originally installed version 2.2.1.x to version 2.5.
The sensor has 6.4GB IDE HDD.
I am using a Sensor Recovery CD-ROM labeled
as follows:
"Sensor Software
Version 2.5
IDS 4230-xx
IDS 4210-xxxx
NRS-xx Appliances
NRS-xx DM Appliances"
After finishing the installation, it stalls at reboot.
It shows:
SunOS Secondary Boot version 3.00
Initializing system
Please wait...
The second time I reboot the sensor,
entering "Bus Enumeration" screen of the Solaris
Device Configuration by pressing F2 key,
and executing the device scanning, it shows:
"Determining bus types and gathering hardware
configuration data ..."
it stalls again here.
Have anyone experienced this problem?
Thank you.
07-02-2001 11:49 AM
Have you tried installing it again?
Please verify that the correct CD is used.
There are 2 CDs for 3.5 sensors.
The first CD installs on the IDS-4230, IDS-4220, and NRS-xx appliances (Large grey sensors)
The second CD is only for the IDS-4210 appliances (small blue sensors), but I don't know if the installation is smart enough to check to ensure that the sensor is a IDS-4210 sensor.
Also there have been problems with different keyboards and monitors. Once the sensor has been reloaded by CD try unplugging the keyboard and powering on and off the sensor.
07-10-2001 05:44 AM
Thank you for your advice.
Sorry for not writing you soon.
I found that the monitor I was using was causing
the problem.
I plugged off the monitor from the sensor, then the
sensor booted up.
Also, when I attached another 17" monitor, the sensor
started up.
The monitor causing the problem is:
SOTEC MC-17K01
(17" MULTI-SCAN COLOR MONITOR)
Every time I try this questionable monitor, the sensor
stalls at the following boot sequence.
Initializing system
Please wait...
About the description of the upgrade
CD-ROM, I made a mistake in writing.
The exact description is:
Version 2.5
IDS 4220-xx
IDS 4230-xxxx
NRS-xx Appliances
Best regards,
Daiichiro Beppu
