Serial / RJ45 adapter
I'm trying to connect to my PIX 506 using the console port which is an RJ45. I've looked into the shops and found the adapter, but you have got to do the wiring yourself. Is there someplace where I can see the pin configuration for the serial?
1 REPLY
Re: Serial / RJ45 adapter
I believe you should find the wiring details you're after here:
http://www.network-cable.co.uk/archive/rs232_cisco.htm
Cheers,
Steve
107
