Setting ASA syslog setting to information - ok?
I need to audit inbound connections to our ASA. It seems the only way is to set the Syslog settings on the ASA to informational, is this okfor the ASA? or very resourceful?
Worst thing is we only need to be notified when a server webserver gets access, so is there a better way?
1 REPLY
Silver
Re: Setting ASA syslog setting to information - ok?
syslog is meant for giving hints to the user or administrator about the problem or failures happend or going to happen as warning through error messages.Webserver access can also be checked throughj syslog.Refer the following url for more details on syslog:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a2e04.shtml#capturevpn
To create a logging list to use in other commands to specify messages by various criteria (logging level, event class, and message IDs), use the logging list command in global configuration mode. To remove the list, use the no form of this command.
refer the url below for more info on "logging list":
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/l2.html#wp1731873
103
