Community Member
Setting up a PIX-PIX VPN with Dynamic and Static IP's
Hey everyone..
I'm recently working to deploy two PIx-506E devices at a remote site and at my home.
I want to be able to connect these together and eventually create a spoke and hub method of deployment to keep several of the places I manage separate but accessible.
The only problem is almost every example I've seem has two static WAN IP's. I cannot have a static WAN at my home, but it will be available for every remote.
How could I go about this? Any articles you can shoot my way and modify so it would work will help me.
Thank you.
Michael Jankowski
Computer Systems Consultant
Community Member
Re: Setting up a PIX-PIX VPN with Dynamic and Static IP's
i faced similar problem. then i used dynamic dns.
see this:http://www.dyndns.com/services/dns/dyndns/
may this wil help
Community Member
Ok I will register... but I'm a little confused on what the easiest method would be to set up a network like that?
Gold
You van deploy EZ VPN server scenario
Remote will VPN server and home will Easy VPN client (there is no need for static IP)
Check this link for more info
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008019e6d7.shtml
M.
Hope that helps rate if it does
Hall of Fame Super Blue
In addition to what has been said.
If you are looking to set up site to site VPN's and you don't have a static IP at youe home you can use dynamic crypto maps which allow you to use dynamic ip addressing. You can mix and match so you can use a fixed ip for your remote site and a dynamic ip at home. Attached is a link which explains dynamic crypto maps
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093f86.shtml
140
