Community Member
severity from VMS
It;s wired, the severity of a even can be changed automatically. I asked VMS to notifi me when there is a event with severity high, ID 4701 once is on the list, show red from even viewer, now it is not on the list, the color turns green.
Also, I am not sure how the block works, do I need access to router or switch?
Silver
Re: severity from VMS
I am not able to figure out what is the exact information you are looking for. You can refer to the VMS documentation to find out how it works.
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/vpnman/vms_2_1/
Community Member
Thank you for your URL.
I am wondering why the color on ms sql buffer overflow was changed from red to green a few weeks ago.
103
