Signature not shown on events monitor or reports
When tracking MSBlaster using snoop, it shows many internal source IP addresses going out to the internet. Do you know why Sig id 5365 is not shown on the events monitor or any type of reports? The sig id is enable.
Kim.
  • Other Security Subjects
Re: Signature not shown on events monitor or reports
Assuminig you are using 4.x issue commands:
sensor(config)#service netw
sensor(config-NetworkAccess)#show settings
Look at the signature enabled on the sensor
Thank you for your reply.
We are using 3.x and the sig is enabled. Question is why VMS does not show what we see on the sensor?
Has it worked and then it isn't working? What sp/sig level are you at presently?
We are using S58. Is there a signature that we can custom or one that exists to show machines that are excessively sending SYN packets to every single subnet on the internet?
102
