simple ACL question to allow VPN client through
Hi - I have a simple question. A machine on our network is running the Nortel Contivity software VPN client on his machine. The machine is NATted on our Cisco 2610 router. I want to create an access-list entry to allow VPN traffic to and from this machine to a particular IP address on the Internet. The VPN client uses IPSEc and ISAKMP key exchange.
Make sense? Anyone know the line? I have the IP Firewall IOS (but do not have CBAC turned on just yet - just the access lists).
  • Other Security Subjects
Re: simple ACL question to allow VPN client through
Depends on which way your ACL is set up, inbound or outbound. Basically you want to allow the following:
> access-list 100 permit udp eq isakmp
> access-list 100 permit esp
> access-list 100 permit ahp
If this is applied inbound on your Interet-facing interface, then will be the Nortel VPn gateway and will be the Nortel VPN clients NAT address. Keep in mind that for this to work properly you'll probably need a one-to-one NAT translation for this internal VPN PC.
another stupid question I guess - I'm getting '% incomplete command' after typing in that first permit udp message. I type in the as an IP addres and as another, should I be putting in netmasks (or inverse masks)? i'm rather new at this.
Oops, sorry about that, that's two typos I made yesterday, I must be getting rusty.
what you need to enter in is:
> access-list 100 permit udp host host eq isakmp
> access-list 100 permit esp host host
> access-list 100 permit ahp host host
Sorry about that.
102
