Simple question about CSC-SSM
I must block a HTTPS website using CSC-SSM on a ASA 5520 but it looks like it won't block HTTPS traffic at all so I've been searching around and I found that "Traffic that moves through HTTPS cannot be scanned for viruses and other threats by the CSC-SSM software.".
Anyone has sucessfully blocked HTTPS traffic using CSC-SSM?
Which other blocking methods would you recommend? ASA's URL filtering?
Thanks in advice.
Guilherme
Re: Simple question about CSC-SSM
hi Guilherme
the idea with https it is a secured http with sslor tls which is the same idea with vpn/IPSEC where the traffic is tunnled and cannot be inspected before get devrypted
which wshould be the same with all vendors
if u can inspect the https and scan it then it is not secure enough !! right :)
good luck
if helpful Rate
YES.
Websense and n2he do support https filtering.Check their website for further details.
Sushil
132
