Simple question: How i block an external IP?
hi.. i am new here and dont understand much about firewalls, but i need to block an internet IP that attacking my network, how i can do it?
i try some configs but nothing work
where i can read some basic manual to configure mi firewall?
Here is my info
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Re: Simple question: How i block an external IP?
hi,
find out the IP address first, then make an access-list and apply it on outside interface
access-list 100 deny ip host any
access-group 100 in interface outside
if you already have an ACL applied on outside interface, then you have to add the deny first
thanks
Nadeem
If you often have to block such hosts it might be good to use object groups. Like that you can easy add and remove hosts in the object group instead add and remove them in the access-list. This helps also to keep short your access-list.
Blacklist on outside interface example:
object-group network Blacklist
network-object host x.x.x.2
network-object host b.c.y.x
exit
access-list outside deny ip object-group Blacklist any
access-group outside in interface outside
examples:
Controlling Network Access and Use:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a008017278e.html
Configuration Examples and TechNotes:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_configuration_examples_list.html
Using and Configuring PIX Object Groups
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800d641d.shtml
sincererly
Patrick
230
