Community Member
simple question: showing numbers, not names
For example, when I do a sh object-group, it shows all the names of the hosts in the group; for example:
object-group network HSTMAIL01
description: Hosting Mailservers
network-object HSTMAIL01-66 255.255.255.255
network-object HSTMAIL01-67 255.255.255.255
Basicly what I want to know is how instead of showing HSTMAIL01-66, I want it to show the actual IP address of the hosts.
Community Member
Re: simple question: showing numbers, not names
Ah ha -- I answered my question myself... 'sh name' shows all the name -- IP definations
Community Member
F.Y.I.
you can use the follwoing command to view ip addresses instead of names when you do a show config:
no names
if you want to view the names, use the command:
names
vik
Community Member
wow thanks! I was wondering how you did that.
-Chris (ee99ee)
100
