single crypto with two peer
dear All,
issue : cisco 2811 , IP sec tunnel establishement with single crypto defined but two set peer
ip address.
i want to know :
In a single crypto map if i define two peer IP address (set Peer ) then did the VPN will come
up from both the Peer IP OR it will try from the first one and then switch back on the second
set peer. if later is the case then what are the reasons for causing switch back. .
Rgds,mac.
1 REPLY
Re: single crypto with two peer
If the first one is no longer reachable, it will fall-back to the second peer.
Farrukh
99
