sink hole & IDS
I want to know how works IDS sensors and CSPM with sink hole technique.
Silver
Re: sink hole & IDS
Cisco's IDS/CSPM does not have this built in functionality to trigger creation of the sink hole. If the sink hole is created by the user then the Cisco IDS can be used to monitor the sink hole. If I remember correctly, CSPM does have the ability to execute user created programs/scripts. If you created your own script to setup the sink hole then you could get CSPM to execute that script when certain alarms are seen. But you would have to create this script yourself.
Re: sink hole & IDS
Thanks for the information.
Can you help me with some links or examples regarding to this ?
What is better to use for manage with sink hole : CSPM, IDS Director or IDS Manager and Event Viewer ?
Best regards
88
