Community Member
I'm fairly new to configuring the ASA firewalls and I'm currently stuck trying to figure out how to allow incoming SIP calls into the to the firewall. I've read some documentation on how to create a NAT rule, but I'm assuming because of my setup using straight NAT is not possible. I know that my description is a little vague. If any other information is needed please let me know. Here is my current config file:
ASA Version 7.2(2)
hostname firewall
enable password XXXXXXX encrypted
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd XXXXXXXXXX encrypted
ftp mode passive
dns server-group DefaultDNS
access-list 101 extended permit tcp any gt 1023 interface outside eq ssh
access-list 101 extended permit tcp any gt 1023 interface outside eq sip
access-list 101 extended permit udp any gt 1023 interface outside eq sip
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
static (inside,outside) tcp interface www Mythtrix www netmask
static (inside,outside) tcp interface ssh Mythtrix ssh netmask
static (inside,outside) tcp interface sip Mythtrix sip netmask
static (inside,outside) udp interface sip Mythtrix sip netmask
access-group 101 in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
username nick password XXXXXXXXXX encrypted
aaa authentication ssh console LOCAL
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh inside
ssh timeout 60
ssh version 2
console timeout 0
dhcpd auto_config outside
dhcpd address inside
dhcpd dns interface inside
dhcpd domain interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_pol
