Site - Site VPN using routers and private ip on serial link to ISP
I am connecting a remote site to HQ using 2611XM routers and IPSEC. I did a very similiar setup a few months back and everything went great. This time however, the remote site ISP has provided a Private IP on the serial link to the Internet. I have been provided a set of public IP's which I use to NAT (PAT) the private internal network.
My question is how do I define the peer address for the crypto command on my HQ router ? Normally, the peer address is the address of the serial port of the remote router. Here in this case, it is a private IP and hence how do I define it.
interface FastEthernet1/0
ip address 192.168.54.1 255.255.255.0
ip nat inside
interface Serial1/0
description Link to the Internet
ip address 172.19.200.62 255.255.255.252
ip nat outside
ip nat pool RG-Geoge-natpool 210.106.219.241 210.106.219.241 netmask 255.255.255.248
ip nat inside source list nat-list pool RG-Geoge-natpool overload
ip classless
ip route 0.0.0.0 0.0.0.0 172.19.200.61
ip access-list extended nat-list
permit ip 192.168.54.0 0.0.0.255 any
  • Other Security Subjects
1 REPLY
Re: Site - Site VPN using routers and private ip on serial link
you have defined a nat pool 210.106.219.241 which is not part of your configured IP segments. If this config is correct, then your serial interface has to be "natted" also by your ISP to a public IP adress. Then you can build a crypto map in tunnel mode on the serial interface. On the remote site you must define the peer address as your ISP does the NAT-address for your serial interface. CAUTION: IPsec NAT is not provided by every Router and even not by every CISCO IOS. So talk to your ISP and get a public address and also get clear that ESP providing is enabled.
Hope this helps a bit
Regards Norbert Steup
148
