Site-to-site and Client-to-site
We have a 7140 in a hub office with 2651s dotted around the region all running 12.2.8T1 and setup with ISAKMP key negotiation, IPSEC 3DES and GRE tunnels (to shift the OSPF). The Interface (F0/1) that sits on the Internet has an ACL allowing only IPSEC AH, ESP and ISAKMP through.
The problem comes when we try to attach a Client VPN 3.5.1c (see config of router below). The client connect and all keys are exchanged but when it comes to moving data across the Client VPN connection no protocols work - if I remove the ACL the client works fine and can use all IP protocols that it needs to.
How can I run site-to-site VPNs and Client-to-site on the same box with the maximum security? Cisco's examples only show one or the other not both together!
Thanks, JB.
----- Config - this is a cut down version and not totally verbatim!
aaa new-model
aaa authentication login remoteuser group radius
aaa authorization network remotegroup local
aaa session-id common
enable secret 5 <blarrr>
clock timezone GMT 0
ip subnet-zero
no ip domain-lookup
no ip bootp server
ip audit notify log
ip audit po max-events 100
! policy 1 for the site VPn tunnels
crypto isakmp policy 1
encr 3des
authentication pre-share
group 5
! policy 999 for the client vpn tunnels
crypto isakmp policy 999
encr 3des
group 2
crypto isakmp key <somekey> address <remote_ip> no-xauth
crypto isakmp identity hostname
crypto isakmp client configuration group ClientVPN
key <anotherkey>
dns 10.60.24.21 10.60.2.19
wins 10.60.2.19 10.60.24.22
domain <aaa.com>
pool remote_vpn_pool
crypto ipsec transform-set site_e ah-sha-hmac esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set client_e esp-3des esp-sha-hmac
crypto dynamic-map DynamicVPNs 1
set transform-set client_e
crypto map RemoteVPNs client authentication list remoteuser
crypto map RemoteVPNs isakmp authorization list remotegroup
crypto map RemoteVPNs client configuration address respond
crypto map RemoteVPNs 1 ipsec-isakmp
set peer <remote_ip>
set transform-set site_e
match address ACL
crypto map RemoteVPNs 999 ipsec-isakmp dynamic DynamicVPNs
controller ISA 5/1
interface Tunnel1
bandwidth 4096
ip address <tunnel_add> <tunnel_mask>
ip mtu 1440
tunnel source FastEthernet0/1
tunnel destination <remote_ip>
interface FastEthernet0/0
ip address <internal_ip> 255.255.255.0
duplex full
speed 100
interface FastEthernet0/1
ip address <external_ip> 255.255.255.128
ip access-group 101 in
duplex full
speed 100
router ospf 1
passive-interface FastEthernet0/1
network <stuff>
ip local pool remote_vpn_pool 172.16.1.1 172.16.1.254
ip classless
ip route 0.0.0.0 0.0.0.0 <external_isp_router>
ip route 172.16.1.0 255.255.255.0 FastEthernet0/1
ip access-list extended ACL
permit gre host <local_ip> host <remote_ip>
access-list 101 permit esp any any
access-list 101 permit ahp any any
access-list 101 permit udp any eq isakmp any eq isakmp
access-list 101 deny ip any any
radius-server <stuff>
1 REPLY
Re: Site-to-site and Client-to-site
Often times complex configuration issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
91
