Site to site and remote access
Is it possible to terminate a site to site vpn and a remote access vpn on the same Cisco 871 ISR?
Re: Site to site and remote access
Sure it is, your crypto map just has two instances, one a static pointing to the remote site-to-site peer, then a dynamic instance for your VPN clients coming in.
Something like:
crypto map test 5 ipsec-isakmp
   set peer 1.1.1.1
   set transform-set testset
   match address 115
crypto map test 10 ipsec-isakmp dynamic test-dynamic
Yes, there are two nuances:
1) You have to add dynamic entry after static in crypto-map configuration.
For example:
crypto map crM1 10 ipsec-isakmp
crypto map crM1 500 ipsec-isakmp dynamic crDM1
2) You have to add no-xauth keyword to avoid XAUTH authentication for site to site connection
For example:
crypto isakmp key 0 cisco address 192.168.1.1 no-xauth
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094685.shtml
135
