site-to-site by GRE tunnel with ADSL
i have a VPDN ADSL line which gets fixed IP 192.168.104.85,gw:196.168.150.1(1841 router connects to ADSL modem by F0/1); it will connects to 10.10.12.5 which is my centeral cisco router. the VPDN is provided by my ISP. the remote site can access central successfully, but the central can't access the remote, and only access 192.168.104.85. so i am considering to use GRE tunnel for site-to-site access, but the tunnel interface on remote router's state flaps from up to down every 20 seconds, from down to up every 10 seconds. i don't know how to solve it, anybody help?
hostname C1800
logging buffered 51200 warnings
enable secret xxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppoe
request-dialin
protocol pppoe
username xxxx privilege 15 secret xxxx
interface Tunnel0
ip address 10.200.200.2 255.255.255.0
no ip redirects
ip mtu 1492
tunnel source 192.168.104.85
tunnel destination 10.10.12.5
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 172.x.x.x.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxx password 0 xxxx
no ip classless
ip route 0.0.0.0 x.x.x.x.168.150.1
access-list 1 permit any
dialer-list 1 protocol ip permit
*Apr 19 07:51:35.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, c
hanged state to down
*Apr 19 07:51:45.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, c
hanged state to up
*Apr 19 07:52:05.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, c
*Apr 19 07:52:15.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, c
hanged state to up
*Apr 19 07:52:35.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, c
*Apr 19 07:52:45.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, c
hanged state to up
*Apr 19 07:53:05.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, c
Re: site-to-site by GRE tunnel with ADSL
Do add a static ip route for the central site network on your router towards the tunnel interface so that the traffic destined to your central site can take the tunnel path.
ip route 10.10.12.0 255.255.255.0 tunnel0
The same way you need to route the branch router local network towards your tunnel interface there in your central site
ip route 172.168.124.0 255.255.255.0 tunnel0
Once you are done with this you will be able to ping both the lans..
regds
Silver
I think the tunnel is flapping because of recursive routing or if the pppoe is flapping. Is the connection stable or do u have any routes pointed to the tunnel ?
the connection is stable because i can always ping the remote router's Dialer1 192.168.104.85 from the central router.
from the remote router of 1841, i see that there are only incoming packets,but not any output packets. so strange.
Silver
Can you make it ip classless and check ? And as Edwin pointed out ensure you have the necessary routes to the tunnels.
Hall of Fame Super Silver
As I look at the config I believe that the basic problem is, as Edwin suggests, the configuration of static routes on the router. Currently the configured default route sends all remote traffic to the routers next hop gateway:
unfortunately this bypasses the tunnel. This explains the difficulty with traffic going out of the router.
I would suggest that the configuration be changed so that the default route points to the remote end of the tunnel as its next hop. Probably it would be this:
ip route 0.0.0.0 0.0.0.0 10.200.200.1 (or whatever address is the other end)
I also suggest that a static route be added for the destination address of the tunnel:
ip route 10.10.12.5 255.255.255.255 192.168.150.1
This will assure that tunnel packets will be properly routed (otherwise there will be a recursive routing problem and the tunnel will not work).
Rick
thanks for your kind help. but i still failed after i configured as you suggest.
the tunnel interfaces at both ends were down even after i 'shu/no shut' them, but the Dialer interface at remote site and Serial int at central site are up. when should the interface be down and how to get them up?
hi
Is it possible for your to post out your central site configs ? i feel that may provide some vital info..
Also when both your interfaces are up connected on both the sides you can verify the connectivity between the locations using a simple ping to the destination ip which you configure in your tunnel config which can give some rough idea in narrowing down the possibilities involved..
regds
284
