Site-to-Site Cisco IOS 805 and Contivity
I'm trying to configure an IPSec tunnel between a Contivity and a Cisco IOS router 805 (IOS 12.1 or 12.2) but I had no success. I got the message in the cisco debug ( %CRYPTO-6-IKMP_NOT_ENCRYPTED) Does anyone had already faced this problem and could help me?
Thanks.
Re: Site-to-Site Cisco IOS 805 and Contivity
Need more information to do further troubleshooting.
See following URL helps or not.
http://www.cisco.com/warp/customer/471/vpn_pppoe.html
If it is still not working, please upload your router's config, take off credential information and we will work out what is wrong in there.
Best Regards,
Message
00:07:21: %CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from 20.20.20.1 was not encrypted and it should've been.
Configuration
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname c1721
logging buffered 4096 debugging
enable secret 5 -- moderator edit --
enable password 7 -- moderator edit --
clock timezone BRA -3
ip subnet-zero
no ip source-route
no ip ftp passive
no ip domain lookup
ip domain name rj.telemar
ip dhcp pool localpool
import all
network 192.168.134.0 255.255.255.0
default-router 192.168.134.1
no ip bootp server
ip audit notify log
ip audit po max-events 100
ip cef
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp policy 3
encr 3des
hash md5
group 2
crypto isakmp policy 4
encr 3des
group 2
crypto isakmp policy 5
encr 3des
authentication rsa-encr
crypto isakmp policy 6
encr 3des
hash md5
crypto isakmp policy 7
encr 3des
hash md5
crypto isakmp policy 8
encr 3des
crypto isakmp key telemar address 20.20.20.1 no-xauth
crypto isakmp identity hostname
crypto ipsec transform-set nortel esp-3des esp-sha-hmac
crypto map mode 4 ipsec-isakmp
set peer 20.20.20.1
set transform-set nortel
match address 111
interface FastEthernet0
ip address 192.168.134.1 255.255.255.0
speed auto
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
ip address 30.30.30.1 255.255.255.0
encapsulation ppp
no ip mroute-cache
load-interval 30
autodetect encapsulation ppp
fair-queue 4096 16 0
serial restart_delay 0
clockrate 512000
invert txclock
crypto map mode
interface Serial2
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 30.30.30.2
no ip http server
ip pim bidir-enable
access-list 111 permit ip 192.168.134.0 0.0.0.255 192.168.133.0 0.0.0.255
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
login
end
This is a debug output, the same problem to other router
01:06:47: ISAKMP: received ke message (1/1)
01:06:47: ISAKMP: local port 500, remote port 500
01:06:47: ISAKMP (0:42): Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
01:06:47: ISAKMP (0:42): Old State = IKE_READY New State = IKE_I_MM1
01:06:47: ISAKMP (0:42): beginning Main Mode exchange
01:06:47: ISAKMP (0:42): sending packet to 30.30.30.2 (I) MM_NO_STATE
01:06:47: ISAKMP (0:42): received packet from 30.30.30.2 (I) MM_NO_STATE
01:06:47: ISAKMP (0:42): Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
01:06:47: ISAKMP (0:42): Old State = IKE_I_MM1 New State = IKE_I_MM2
01:06:47: ISAKMP (0:42): processing SA payload. message ID = 0
01:06:47: ISAKMP (0:42): found peer pre-shared key matching 30.30.30.2
01:06:47: ISAKMP (0:42): Checking ISAKMP transform 1 against priority 3 policy
01:06:47: ISAKMP: encryption DES-CBC
01:06:47: ISAKMP: hash SHA
01:06:47: ISAKMP: default group 1
01:06:47: ISAKMP: auth pre-share
01:06:47: ISAKMP: life type in seconds
01:06:47: ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
01:06:47: ISAKMP (0:42): atts are acceptable. Next payload is 0
01:06:47: ISAKMP (0:42): Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
01:06:47: ISAKMP (0:42): Old State = IKE_I_MM2 New State = IKE_I_MM2
01:06:47: ISAKMP (0:42): sending packet to 30.30.30.2 (I) MM_SA_SETUP
01:06:47: ISAKMP (0:42): Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
01:06:47: ISAKMP (0:42): Old State = IKE_I_MM2 New State = IKE_I_MM3
01:06:48: ISAKMP (0:42): received packet from 30.30.30.2 (I) MM_SA_SETUP
01:06:48: ISAKMP (0:42): Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
01:06:48: ISAKMP (0:42): Old State = IKE_I_MM3 New State = IKE_I_MM4
01:06:48: ISAKMP (0:42): processing KE payload. message ID = 0
01:06:48: ISAKMP (0:42): processing NONCE payload. message ID = 0
01:06:48: ISAKMP (0:42): found peer pre-shared key matching 30.30.30.2
01:06:48: ISAKMP (0:42): SKEYID state generated
01:06:48: ISAKMP (0:42): Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
01:06:48: ISAKMP (0:42): Old State = IKE_I_MM4 New State = IKE_I_MM4
01:06:48: ISAKMP (0:42): Send initial contact
01:06:48: ISAKMP (0:42): SA is doing pre-shared key authentication using id type ID_FQDN
01:06:48: ISAKMP (42): ID payload
next-payload : 8
type : 2
protocol : 17
port : 500
length : 20
01:06:48: ISAKMP (42): Total payload length: 24
01:06:48: ISAKMP (0:42): sending packet to 30.30.30.2 (I) MM_KEY_EXCH
01:06:48: ISAKMP (0:42): Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
01:06:48: ISAKMP (0:42): Old State = IKE_I_MM4 New State = IKE_I_MM5
01:06:48: ISAKMP (0:42): received packet from 30.30.30.2 (I) MM_KEY_EXCH
01:06:48: %CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from 30.30.30.2 was not encrypted and it should've been.
01:06:48: ISAKMP (0:42): incrementing error counter on sa: reset_retransmission
01:06:49: ISAKMP (0:42): retransmitting phase 1 MM_KEY_EXCH...
01:06:49: ISAKMP (0:42): incrementing error counter on sa: retransmit phase 1
01:06:49: ISAKMP (0:42): sending packet to 30.30.30.2 (I) MM_KEY_EXCH
01:06:49: ISAKMP (0:42): received packet from 30.30.30.2 (I) MM_KEY_EXCH
01:06:49: %CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from 30.30.30.2 was not encrypted and it should've been.
01:06:49: ISAKMP (0:42): incrementing error counter on sa: reset_retransmission
01:06:50: ISAKMP (0:42): retransmitting phase 1 MM_KEY_EXCH...
01:06:50: ISAKMP (0:42): incrementing error counter on sa: retransmit phase 1
01:06:50: ISAKMP (0:42): sending packet to 30.30.30.2 (I) MM_KEY_EXCH
01:06:50: ISAKMP (0:42): received packet from 30.30.30.2 (I) MM_KEY_EXCH
01:06:50: ISAKMP (0:42): phase 1 packet is a duplicate of a previous packet.
01:06:50: ISAKMP (0:42): retransmission skipped for phase 1 (time since last transmission 4)
Looking from the debugs we see that IOS Router is looking for an encrypted packet at this stage from the peer which its not getting, did you try changing the code on the Contivity side? What error message does it show on their side?
Aamir
I found the problem. The crypto isakmp identity hostname command was the problem, when I changed it for the crypto isakmp identity address command everything was solved. Contivity was looking for IP address identity and not hostname...
Willians
329
