Community Member
site to site + Internet connection
i have a site to site Pix connection. Is it possible to allow the remote site the way to the Internet ? I meen no Internet connection over the central site. I meen on the remote site.
Thanks for help,
sebastian
Bronze
Re: site to site + Internet connection
Hi Sebastian
I am not following you. Are you saying that you don't want the traffic destined for the Internat to go ver the tunnel?
If that's the case, make sure that you only include the private subnets in your encryption ACL so that only the private-private subnets traffic gets encrypted
Hope that helps
Jazib
Community Member
ok, if it is possible for a client in the remote network to access the Internet without going over the IPSec tunnel, isn t it a security problem ? Maybe there are some old Win9x clients. If a hacker go on this devices, there is a easy way to connect the central site....
sebastian
Bronze
Hi Sebastian,
yes, it is possible for the client to access the Internet without going over the IPSec tunnel. Enabling ST could be a security hole. If avoid that, you can also enable "stateful firewall" option on the client to avoid accepting inbound connections from the client
Hope that helps
Jazib
264
