site-to-site vpn by using PIX 515
i want to use vpn to connect my office to another office at UK by using PIX 515 at both site. can it be done?
if can, how? can some one tell me or give a sample of configuration at both site. i want to establish the connection between this two location for remote access at our equipment.
thanks.
Gold
Re: site-to-site vpn by using PIX 515
Gold
it depends on the isp assigned public ip.
if both sites have a static public ip, then the options are lan-lan vpn or ezvpn; whereas if only one site has a static public ip, then the option is ezvpn. the main difference between the lan-lan vpn and ezvpn is that with lan-lan vpn, both sites would be able to initiate the vpn; whereas with ezvpn, only the client site (i.e. the one with dynamic public ip) would be able to initiate the vpn tunnel. nonetheless, once the vpn is up, both sites would have full access to each other.
for lan-lan vpn,
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094761.shtml
for ezvpn,
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008019e6d7.shtml
212
