Site-to-Site VPN problem between 2 PIX 515
Hi all,
I want to establish a VPN tunnel between 2 PIX515E, a site-to-site VPN.
I have used the wizard of the PDM.
First, the tunnel seems ok : I can ping hosts on remote site, telnet, etc.
But sometimes, the tunnel seems to be down: I cannot ping remote hosts for example anymore.
I think that when there is no traffic through the tunnel, it's ok that the tunnel is down. And when I try to ping remote hosts, I think that the tunnel should turn to up. Is it correct?
I look in the logs and I notice that whenever I try to ping/telnet a remote host, I generate in statistics:
"PIX pkts no sa (send)".
No packets are encrypted.
Could someone tell me where is the problem?
Thanks you for helping me!
Re: Site-to-Site VPN problem between 2 PIX 515
can you paste the configuration details your
pix device then it will we easier to shortout the issue
Thanks & Regards
Krish
Here is the result of the "debug crypto isakmp" command.. It seems that phase 2 of IKE is not successful...:
ISAKMP (0:0): sending NAT-T vendor ID - rev 2 & 3
ISAKMP (0): beginning Main Mode exchange
crypto_isakmp_process_block:src:remote-pix, dest:A.B.C.D spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 10 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (basic) of 28800
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): processing vendor id payload
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
return status is IKMP_NO_ERROR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): received xauth v6 vendor id
ISAKMP (0): speaking to another IOS box!
ISAKMP (0): speaking to a VPN3000 concentrator
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): processing keep alive: proposal=32767/32767 sec., actual=600/10 sec.
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0): SA has been authenticated
ISAKMP (0): beginning Quick Mode exchange, M-ID of 1370673357:51b2d0cdIPSEC(key_engine): got a queue event...
IPSEC(spi_response): getting spi 0x773f7309(2000646921) for SA
from remote-pix to A.B.C.D for prot 3
ISAKMP (0): sending INITIAL_CONTACT notify
ISAKMP (0): sending NOTIFY message 24578 protocol 1
VPN Peer: ISAKMP: Added new peer: ip:remote-pix/500 Total VPN Peers:4
VPN Peer: ISAKMP: Peer ip:remote-pix/500 Ref cnt incremented to:1 Total VPN Peers:4
<-------until here, it seems Ok, i think?------->
<------- I compare theses lines with the lines I get when it works (in fact, I have multiple tunnels VPN on my PIX A, PIX A <--> PIX B, PIX A <--> PIX C, etc.) and I notice that theses 3 lines are missing....
OAK_QM exchange
oakley_process_quick_mode:
OAK_QM_IDLE
<------- End of the debug: ------->
ISAKMP (0): processing NOTIFY payload 18 protocol 1
spi 0, message ID = 2482419244
return status is IKMP_NO_ERR_NO_TRANS
ISAKMP (0): processing DELETE payload. message ID = 2738261993, spi size = 16
ISAKMP (0): deleting SA: src A.B.C.D, dst remote-pix
ISADB: reaper checking SA 0x10ffe3c, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:remote-pix/500 Ref cnt decremented to:0 Total VPN Peers:4
VPN Peer: ISAKMP: Deleted peer: ip:remote-pix/500 Total VPN peers:3IPSEC(key_engine): got a queue event...
IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
IPSEC(key_engine_delete_sas): delete all SAs shared with remote-pix
ISADB: reaper checking SA 0x10d8c34, conn_id = 0
ISADB: reaper checking SA 0xfea484, conn_id = 0
ISADB: reaper checking SA 0x1106b14, conn_id = 0
Any Idea please?
Hi ,
Can you paste your config Details of both Pix devices
Krish
197
