site to site vpn problem
site to site vpn tunnel problem
i have set up a test network at home to practice setting up a site to site vpn
using cerificate services for authentication but have run into a problem
ie it does not seem to work.
the steps i have taken so far is that i have configured a microsoft server
as the CA and have installed the mscep add-on both pixes at the each end of
the tunnel have successfully obtained their certificates from the CA
the clocks have been set to GMT on the CA and both pixes and after obtaining
their certificates i have set up the pixes in the following manner
pix 515 which is running ios 7.0
access-list 102 permit ip 192.168.5.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 103 permit ip 192.168.5.0 255.255.255.0 192.168.1.0 255.255.255.0
nat (inside) 0 access-list 103
route outside 0 0 192.168.4.2
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication rsa-sig
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
sysopt connection permit-ipsec
crypto ipsec transform-set portland esp-3des esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
crypto map vpn 10 match address 102
crypto map vpn 10 set peer 192.168.2.1
crypto map vpn 10 set transform-set portland
crypto map vpn 10 set trustpoint certserver
crypto map vpn interface outside
crypto ca trustpoint certserver
tunnel-group 192.168.5.1 type ipsec-l2l
tunnel-group 192.168.5.1 ipsec-attributes
trust-point certserver
pix 501 which is running ios 6.3
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list 103 permit ip 192.168.1.0 255.255.255.0 192.168.5.0 255.255.255.0
route outside 0 0 192.168.2.2
crypto ipsec transform-set seattle esp-3des esp-sha-hmac
crypto map vpn 10 match address 101
crypto map vpn 10 set peer 192.168.4.1
crypto map vpn 10 set transform-set seattle
would appreciate somebody having a look at the above configs and letting me know if
anything is wrong
regards
Melvyn Brown
ps i dont think it is a connectivity problem as i used the network to setup a
site to site vpn using pre-shared keys and it worked perfectly.
  • Other Security Subjects
1 REPLY
Re: site to site vpn problem
Melvyn,
You have "Isakmp Identity Address" on your Pix Configuration. If so, that could be an issue for Phase 1 of your VPN Tunnel not coming up.
You have to configure "Isakmp Identity Hostname" when using Certificates and rsa-sig.
In your case, if you have VPN L2L Tunnels or Clients using Pre-shared Keys, then you could configure "Isakmp Identity Auto" and then try to bring up the tunnel, and see if it works.
Please refer the URL for details on the command:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/config/ike.htm
I hope it helps.
Arul
107
