Site to Site VPN with same private LAN
Hi.
We have a requirement to setup an IPSEC VPN using 2 ASA 5520s between 2 of our sites.
The problem we have is that both sites use the same private IP range; 10.101.1.0 / 24.
Is there a way using (possibly using NAT_ to enable this to work?
SITE A:
LAN 10.101.1.0 / 24
PEER 33.33.33.33
SITE B:
LAN 10.101.1.0 / 24
PEER 44.44.44.44
Help!
Re: Site to Site VPN with same private LAN
Mike,
Please see attached link, you need Policy NAT implementation .
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808c9950.shtml
Rgds
Jorgge
that example doesn't quite fit.
what i want is both sides of the VPN to act as if they are within the same broadcast domain?
in a similar way that OpenVPN bridges 2 subnets with its TAP interfaces.
is there a way to do this with Cisco kit?
both ends of the VPN have the same subnet
123
