05-19-2014 07:08 AM - edited 03-10-2019 12:13 AM
Dear all,
I have a ASA-5520 with a SSM-10 module. I need to renew my contract smartnet but only to support IPS Signature and Engine Updates . I found 2 different contract and i'm a bit confused. Can anybody help me ?
CON-SU1-AS2A10K9
and
CON-SU1-ASIP10K9
Thanks in advance!
Solved! Go to Solution.
05-19-2014 09:23 AM
The first SKU (CON-SU1-AS2A10K9) is a bundled support contract for the base ASA and IPS module (including the software subscription for software and signature updates).
The other one is for the IPS SSM (with software and signature updates) separate from the ASA. It's designed for a customer that already has the ASA covered, possibly under a separate service contract. Cisco will generally require that the base ASA unit be covered by SMARTnet before they will sell you the IPS support.
05-19-2014 09:03 AM
Hi cpapageorg.
I think it's better if you contact Cisco Customer service directly , they should be able to provide you the best contract for you.
You can call to the number 1-800-553-6387 or go to the live chat on the webpage cisco.com
Regards ,
05-20-2014 01:33 PM
Hi cpapageorg, you will need to have your serial number ready when you call Customer Service dept. I can also assist you with getting the details. Feel free to contact me directly so we can make sure on the right contract number that you need to renew and the association process. Hope to hear from you!
Angela
ageralde@cisco.com
05-19-2014 09:23 AM
05-20-2014 02:58 AM
Thank you Marvin for your information.
As i understand you can not buy a contract "CON-SU1-ASIP10K9" without a covered ASA ?
05-20-2014 09:57 AM
That is correct.
Of course Cisco can make exceptions but that is usually not done without strong justification.
