xbw
Source addresses need be changed.
I have a case which is showed in attachments.That is in pix outside interface changed the sourecs addresses as illustrate.How can I config the pix.
the changed sources addresses doesn't in the same network with the pix outside interface's.
1 REPLY
Re: Source addresses need be changed.
You might need to post your config in able to help you more... I'm expecting you are applying a configuration like this:
nat (inside) 1 0 0
global (outside) 1
After applying the needed translation commands, do "clear xlate" and then "debug icmp trace" to see how translations work.
Best Regards,
Haitham
105
