05-24-2006 06:35 AM - edited 02-21-2020 12:55 AM
Is there any way you easily can specify a range of ip addresses from a subnet in an access-list in an ASA. I want to apply specific rules to dhcp-clients but I don't want the rule apply to the rest of the subnet.
Something like this:
Access-list Outgoing permit tcp 10.10.10.100-10.10.10-200 eq 80
I know you could do it with object-groups but then you'll end up with a quite messy config with a hundred lines of ip-addresses in different object-groups. So if someone out there know of a better solution it would be great.
Torbjörn Hedström
Sweden
05-24-2006 09:39 AM
i dont think you can put it like that...
one possibility would be making it
access-list Outgoing permit tcp 10.10.10.128 255.255.255.128 eq 80
But you will need to change your DHCP subnet to be 10.10.10.128/25
sorry if im not making sense, i've been using ASA for about a week now :)
05-25-2006 04:12 AM
Thanks for the reply,
You make perfect sense but I'm not so keen on that solution either, in that case the object-group approach will have to do. As going the subnetting route would break the whole ip-plan
The reason the problem arise is that I'm replacing an old linux-based firewall, where you could specify that kind of ranges, to a Cisco ASA 5510.
I've configured a number of Pix'es before but I was hoping the new software in the ASA would permit me to specify this kind of range of ip addresses.
